RedRocket204 wrote:
transamz9 wrote:
RedRocket204 wrote:
transamz9 wrote:
RedRocket204 wrote:
transamz9 wrote:
Today's big gassers have just as much "pulling power" as the diesels.
How many big gassers carry around forced induction at altitude?
Your flatlander statement isn't 100% valid for everyone.
You make a good point but I have to ask. How much power is lost with the altitude? Remember that today's big gassers are making 20% more power then the last generations of force fed diesels and have more gears to choose from. We have to ask ourselves sometimes, how much power do "I" really need? If the OP's 3 gen Cummins did all he needed then why wouldn't a gas motor with 20% more power do? How much towing is really done in the high altitude? If they live there then most likely people will leave to to go RVing. If the don't live there then they usually only visit.
Like said earlier, it might not work for 100% of the people in this world but I doubt there is even 10% of the people in this world that ever see high enough elevation with their tv to even notice a difference in power. I very rarely even use all the power my engines can produce and I would say there are a lot of poeple that can say the same thing.
This is not an absolute but will give you a general idea - Braking HP Loss at Altitude Calculator
You are correct that probably about 10% tow at altitude with regularity but my point being that blanket statements are not correct for the entire towing population.
I live at 8k feet and travel from 5600 to 8k sometimes 5 days a week...but that is mostly unloaded but is still affected by altitude. When I tow, it is from 8k to ???, many times being higher or over multiple passes.
I would actually like to see a big gasser with forced induction but understand that is a niche market.
Beings you need and have the most powerful truck made, mind sharing what you drive so us flat landers know what we need to bring to the table if we head out your way? I mean you know, I would hate to get out there and not be able to pull the hill.
Sorry, but not going to partake in your attempt at belittlement.
Just wanted to point out what may work for you won't necessarily work for the next guy...you know, the whole blanket statement thing? Not sure why you took such offense to it...lighten up a little.
I'm not trying to belittle. It's just not that often that I'm able to pick the brain of someone that tows in the hardest towing environment to tow in the country. I just would like to know what you do it with is all.
Just a few years ago the diesels were at what the Hemi is with a with the altitude handicap. If these diesels worked for the people you speak of then, why wouldn't they work now?
