Road Ruler wrote:
Generally speaking, for towing, I think you will find that a properly set up M-Van will outperform and be safer than your average pick up in many situations. The topic has been discussed many times. Do your research.
I don't have to research anything to know that there are certain laws of physics at work when towing and a heavier, stronger-constructed vehicle is going to be better. Especially when equipped with a stronger transmission, larger brakes and the proper load-rated tires. Not to mention a longer wheelbase and a hitch that is bolted to a hardened steel frame instead of a few layers of stamped sheetmetal making a unibody. Tow with what you want, just stay out of my way chugging up hills as your engine and trans burns itself into oblivion.
Name one situation where a m-van would outperform or be safer than towing with a 1/2 ton pickup.
