majorgator
Oct 30, 2014Explorer
modern family wrote:
Majorgator.. Thanks for the input. What exactly did you use for chambers? Do you empty them? I am not familiar with that, or at least that term.
Here's the link for the Infiltrator Chmabers.
You can get them at Hughes Supply for about $25 each. Home Depot & Lowes have a knockoff brand, which is more expensive but just as good. They quit carrying them in my county because the building department and contractor licensing department are a bunch of whackos and they complained about too many "regular people" using them (ie not licensed contractor).
Either way, they're meant specifically for drain fields, not as a primary septic system. However, in a shop application, they work fine. You won't have the "septic" characteristics, but presumably you only use your shop bathroom less than once a day (maybe more like a few times a week). If you put 2 or 3 of these chambers end to end, you will NEVER have a problem with the waste buildup, because it will degrade quick enough. People commonly are using these to re-route their washing machine drains so that it doesn't go to the septic tank.
