ntsgiggles wrote:
I run the inverter off the main trailer power plug same as the generator .If I shut the breaker off to the converter will the inverter still power the plugs through the main power cord tho ?
Yes. It will also power the refrigerator and hot water heater if it is gas/electric.
Look in your power center and you will see circuit breakers like in your home. There will be a Main, Air Cond, Micro, Recept, Converter, etc. If I was connecting my 1000w inverter to my shore input like your doing I would shut off all of these breakers except Main and Recept (receptacles (outlets)). Also ensure your fridge is set to gas.
-Jeff
