J_Dubya's avatar
J_Dubya
Cab clearance
Hi everyone. I have a 2000 bigfoot 25c10.6 that I used to haul on my 95 standard cab f350 , it would haul it but it was over taxing the truck . I recently bought a newer f450 to haul this beast .... Well when I began to load it on the truck I noticed the cab lights were far to close to the bunk and would not last if I used the camper without adding some plywood to raise the height a bit.... Fast forward , I had to add about 4" to get enough clearance . My plan is to use blue board sandwiched between ply as well rubber mat on the top and bottom .
If anyone has had the same clearance issues please let me know and post pictures of what you did to correct it. Thanks JW
  • With you needing 4" of lift, I would think about framing out a platform than might give you some storage for poles or hoses underneath. The weight of the camper is on the outside edges of the base, so this where you would concentrate your frame. The platform would have a rubber mat on both sides to prevent slipping on the truck bed or the camper slipping on the platform.
