mooring_product
Apr 24, 2014Explorer
mkirsch wrote:
AFAIK the only manufacturer that makes cabover struts is Lance.
I suspect they don't make them, mostly because they haven't had any call for them. You don't see many Megacabs to begin with, let along Megacabs hauling TCs, let alone Megacabs hauling LANCE TCs, let alone Megacabs hauling Lance TCs large enough for cabover struts. IIRC, Dodge/RAM does not recommend hauling a slide-in TC with a Megacab. On top of that you don't see many cabover struts either.
Lance doesn't manufacturer them, they just sell them. I couldn't get an answer from them as to why they don't have a setup for my truck.
The new RAM is recommended to haul slide in campers. I'm just a little over the recommended weight.
My issue is porpoising. Its not bad but annoying.
Is it possible that when adding water to my holding tank that the ride is better?
I'm also going to look into shocks (Rancho 7000) and maybe some front Timbrens to stop the front from bouncing.
44,060 PostsLatest Activity: May 06, 2023
