enblethen wrote:
I don't think you want the rig sitting on the bump stops. This would effectively defeat the purpose of the springs.
I think there may be a confusion here about which bump stops are being discussed. On a truck with overload springs, there are 2 types of bump stops in the rear suspension.
One set of bump stops (4) is for the upper overload springs, usually 2 on each side of the frame, positioned above the ends of the springs. These give the overloads something to act against to help support the truck.
On most stock trucks, the factory has positioned the overload bump stops up too high on the frame to be effective, until the truck is so grossly overloaded that it is almost at maximum suspension compression height. This is why most truck camper folks here use Stable Loads, or other home-made solutions, to effectively drop the overload spring bump stops down lower, which causes the overloads to come into play sooner, before the truck is dragging it's bumper on the ground, so to speak. :)
The other set of bump stops (2) is for the axle, on the bottom of the frame rail directly above the axle tube. These limit the axle from hitting the bottom of the frame at full suspension compression.
It is highly desirable to have the loaded truck ride on the overload spring bump stops.
It is never a good idea to have any vehicle riding on the axle bump stops.
I agree with all the others so far who have said to lower the air bag pressure and install Stable Load bump stop extensions to let the overloads do their job sooner in the game.
As for the rear tire pressure, 65 psi is enough for your dually to support the camper just fine. I run my dually rears at 65 psi and have 8000 lbs rear axle weight daily. No problems with insufficient tire pressure. If it were a single rear wheel truck, then definitely you would want to run them at max 80 psi, as I do with my other, single wheel F350.
I've never owned a Lance, which is the only camper brand I know of that recommends using cab struts and actually designs their campers to be used with them. If I owned a Lance, I would likely use the cab struts. Any other brand, I wouldn't, and havent. They do seem like a very good idea, for those campers that are built such that the struts won't stress and crack the camper overcab framing.
One other consideration. I see from your picture that the rear axle on your truck is quite far forward, due to the short MegaCab bed length. It is possible the campers front/rear center of gravity point may be positioned reward of the rear axle's center line. This can cause the camper's weight to unload the front axle, which can aggravate porpoising, rocking and steering/handling of the truck. You should seek to load weight of personal items as far forward as possible in the camper, or in the rear seat of the cab, if you can. Keep your waste tank(s) empty too, as they are usually at the rear of the camper.
