blt2ski
Jun 15, 2015Moderator
You have close to 2000 lbs of payload before hitting max axel limits, 1700 on the rear, 300 on the front. Front difference is pretty normal for a pickup of ANY sort shape or form frankly. Adding 1000 lbs to the hitch along with you, you still have some room.
I would try it personally, make sure the hitch is setup properly etc. I was over the gvwr in my SW K3500 about 90-100% of the time by upwards of 300 lbs or so, Had 300 to the fa, 500 to the ra max. Never had what I would call a white knuckle issue that could be related to overall weight etc. I was also 3000 lbs over my gcwr, but an auto version would have been ok, manual not! BUT, every one I know with an auto, did worst performance wise than I did! not sure what is up with that.
I will admit, a 25 series would be better. As one of my personal rules of thumb is no trailer greater than 2x the GRAWR of the truck. A 3950 puts you at 7900 lbs. Your "Want" trailer is a bit heavier. not too far out of whack, but heavier than I would want, none the less!
Marty
Marty
