Pangaea_Ron
Jun 29, 2014Explorer
popeyemth wrote:
20 Mule Team Borax is the same as Calgon except usually cheaper.
It's mixed with water in the black tank,why would it matter if liquid or powder?
I don't even mix mine just dump it down the toilet with detergent and a bucket of water and let the motion on the road mix it for me.
I find its much more convient to pre measure a cup of each an store in baggies. No fussing on the road and worse case of a spill just sweep it up.
Folks make it lots harder than need be.
Good Luck, Mike
Here's a bit more information about Calgon and 20 Mule Team Borax:
Super Washing Soda, White King & 20 Mule Team Borax: Precipitating water conditioners, they bind the minerals in the wash water but minterals can redeposit if not rinsed out really well. Can cause minerals to build up on fabric and the inside of your washer. They can also be irritating to skin if not rinsed very well.
Calgon: Calgon is a non-precipitating water conditioner and binds the minerals into a solution that does not redeposit on clothing or the inside of the washer. It must be added to both the wash water and the rinse water for highest effectiveness. It is more gentle to clothing and skin. It is also more expensive to use.
I pre-mixed White King powder in water bottles, when liquid Calgon was not available, to add to my holding tanks. The powder solidified into solid crystals that completely filled the bottles and could not be removed. I did not want that mixture in my holding tanks.
