IdaD
Jan 15, 2016Explorer
FishOnOne wrote:rhagfo wrote:FishOnOne wrote:Me Again wrote:
The new 3500 MY 2013+ and 2500 MY 2014+ have a redesigned frame and front end. It should no longer be a concern.
Chris
You sure about that... Sorry but the fanboy has to be called out. :R
RAM Death Wobble 1
RAM Death Wobble 2
RAM Death Wobble 3
And yes the current Ford front suspension has the same issue. :W
Ford Death Wobble
Wow Fish are you feeling Ok? :h
Posting that a Ford has the same issue as a Ram.
I have never had this issue on my 2001, but will say that one of the first things I did to help with a bit of wander, was to add a steering shaft brace. This could the simple fix for both.
Not sure if the videos inside or outside look scarier, the outside view on the Ford looks really bad and it has stock sized tires.
Thanks for sharing.
I'm feeling just fine... You know the guy just has to be called out. Sorry to interfere but when the fanboy posts just down right false information someone has to call him out and I do it to this guy all the time. And yes Ford has the same issue as well. All SFA trucks can be susceptible to this issue. Worn tires, underinflated tires, worn or damaged suspension parts can cause this problem.
At a measly 84k miles my truck hasn't done it either, but to say it's not a concern to anyone would flat out be a lie.
Glad I could set the record straight.
Yet you blow a gasket when anybody mentions the very real (and very expensive) CP4 injection pump issue to prospective Ford buyers. Weird.
44,068 PostsLatest Activity: Jun 05, 2026
