HappyKayakers wrote:
Thanks for the input folks. Still waiting for the new lugs and nuts to arrive. Since the mechanic is just across the street, I'll give it a shot myself. My big concern was getting the drum/rotor combo off. If that's really not necessary, so much the better. If it is necessary and I can't get it off, I'll just throw the wheel back on and drive it across the street.
I think you’ll have to remove the wheel, brake calliper and rotor before you’ll be able to knock your studs out of the hub. If you want to remove the rotor without removing the axle and hub it might take a little persuasion.
