SidecarFlip wrote:
...and I thought the fan was attached to the cover...not. You still need to place the tiny fan in the fridge vent (somewhere pointing up. For 20 bucks you can buy 2 muffin fans and for 5 bucks a snap action t'stat and be farther ahead air volume wise. Thats what I did. I'm running a pair of FDB 120mm muffin fans pulling over 100 CFM out of the cavity, wired to the 12 volt terminal block on my dometic.
That's a great point. I had thought it was a turn key solution, just screw it on and it takes the rest. If I have to run wires and find mounting holes then it sort of defeats the idea of being a ready run solution. Not that I can't do the work but was hoping for something a little more complete to avoid adding another project before the trip.
