Kayteg1 wrote:
My conversion is Sprinter van, who has front seats pedestal and that is where the heater fits perfectly.
My van already had aux fuel pickup, so I used it, but reading how low temperatures affect heater priming and that the aux pickup ends at about 1/4 fuel tank, I am keeping the heater tank as spare.
It is 5 kW heater. I don't have much use on it yet, so don't know all the specs, but when running on low speed, it suppose to draw ca 1 amp.
The 5 l (1 gallon, 1 quart) tank suppose to last for 2-3 days.
tons of youtube videos about those heaters.
It seems those units are really working well for a lot of the van crowd. I bet it won't be long until the camper crowd turns on to them. IMO, a much better option then wood. Way more heat for a given cubic inch of stored fuel. Plus they blow so one could rig it to heat basement model TC's.
With the diesel heaters being dryer to heat with then the propane furnaces, they'd be worth trying to install in place of the traditional furnace.
Interested to hear your experience with your 5000 btu unit in a van. I've seen a few van'ers recommend staying with the smaller one as it it gets run on 'HI' more, burning off the soot build up. With the 5000, they were running it lower. That lead to soot build up and failure. (Some didn't realize they just had to clean it until after they tossed it out....opps!) So it has to be cleaned or run full blast for a while to burn off the soot.
So if you can, please keep us posted how it's working for you.
