diazr2
Feb 28, 2014Explorer
Why would you have to cut the cord to do that? Just use your extension cord with the main line. Just don't try and pull the main line all the way out. Just pull it out a ft or two. When you only use an extension cord you don't get the use of all the electrical power in your rig. Smaller cords mean more heat build up in the line and more problems your solution should include leaving the main cord it's the best option. IMHOP. The electrical guys on this list will be able to give you the reasons for this. But just know bigger is better.
44,060 PostsLatest Activity: May 06, 2023
