RoyB
Feb 28, 2014Explorer III
Just be sure you connect up all three wires in the plug/connector (HOT-NEUTRAL-GROUND) if you make changes.
This is the only way the trailer frames get its FRAME GROUND for lightning protection through the THREE WIRE Shore Power Cable..
I personally like the DISCONNECT TYPE Shore Power Cable best but it does require you to find a suitable storage place for it when not in use. Being disconnected also makes it a prime target for thieves.
If you disconnect the 25-foot pull-out RV30A shore power cable be sure to purchase a RV FEMALE PLUG and make an RV30AMP Extension Cord out of it... We seem to always have a need for another RV extension cord around here. Some camp grounds doesn't have their PEDESTAL close enough some times.
Roy Ken
Roy Ken
