MikeJinCO
May 18, 2013Explorer II
I had a 2500 9.4. I had a mule deer side swipe us and strip both jacks on one side right off. There appears to be a wood or plywood backing plate embedded into the plywood inside the fiberglass. I drilled out the brackets and went two sizes up, I think to 3/8" SS lag screws that I probably got from Belmetric Bolt.com due to the high cost from local hardware. Even with shipping they were much cheaper, the local Fastenal was double the cost of the local hardware. Make sure and drill a clearance hole thru the fiberglass, then a pilot hole into the backing plate. A bolt that is tight in the fiberglass will overstress it and cause cracking.
44,066 PostsLatest Activity: Jul 25, 2018
