moomps's avatar
moomps
Campground Etiquette and Protocol
I just purchased a TC - a 1990 Sun-lite Hideaway 850wt. I have a few questions about the information that previous owner gave me. The first is that the TC doesn't have a gray tank - just a piece of PVC that hooks to the kitchen drain coming out of the side and down to the ground. My first question is - is this OK to just let drain on the ground or should I put a bucket under it to catch it so I can dispose of it correctly? Also - the fresh water tank just has a drain that comes out the bottom of the camper so I don't see any problem with letting that one go when I get home on my driveway. But, with no gray tank, there is no way to use it to flush the black tank so I am going to get one of those wands to flush the black tank. Any other thoughts or words of wisdom? Thanks
  • You'll notice after you stay in a few places that almost all campgrounds, public and private, prohibit dumping of gray water. Those rolling totes may be a good solution for you.
  • By no means should anyone ever crack the valve in a campground. I had a portable tank that had wheels and a handle to pull it to a sewer pipe. Just dont let it get too full since it will get heavy.
  • At least use a bucket to transfer grey to bushes or vault or whatever is appropriate for that campground (rules definitely vary by location so check).
    The guys on the popup/folding trailer section of the forum know ALL about this since all but the largest of popup trailers also lack grey tanks.
  • You don't want to dump gray water on the ground at a campground. It smells and dogs will roll in it. There are several styles of storage tanks with wheels you could use to hold the gray water, then take it to dispose in a better location.
  • If you have room, I'd consider adding a grey tank. I wouldn't just dump the grey on the ground. You can buy a storage tank with wheels. Check out camping world for examples.
    I think most of us dump our fresh water on the ground when we are home, or at our storage location. Sometimes, I dump the freshwater into buckets to water plants.
