skipnchar
Sep 03, 2013Explorer
Unless you plan on keeping it as a reminder off of your adventures you will need to dump your tanks. Best place to do that is the dump station. I would guess you hooked up an open tank to the sewer before and if true it's just a matter of time until you have worse things to worry about than dumping, leave that valve closed until the tank is nearly full then open it. True whether using dump or sewer hook up.
