When dry camping and you need to use the furnace to keep warm / or to get the chill out in the morning, living in Illinois in the month of May weather is unstable especially at night. Will I be able t...
Let's not exaggerate the situation - the OP is asking about dry camping over the Memorial Day long weekend where even in Illinois it won't be that cold, really no different than here in S Ontario. If at all he'll end up using his furnace only intermittently just to take the chill off so significant battery drain won't be an issue at all - not the same at all as camping when the temps are consistently below freezing.
