handye9
Jan 12, 2015Explorer II
chracatoa wrote:
No, nothing is enclosed (except the ones that are inside the trailer of course).
I think I can keep some anti-freeze in the tanks. I'm worried about the pipes.
Yes, it is rare to get to 25F at Ocean Shores though it happened at least once :)
Maybe I can let the faucets dripping a little bit?
Dripping faucet won't work. It's not enough flow to prevent the fresh water hose from freezing, and, it will either overflow your grey tank or freeze up your dump valve and sewer hose.
Fill the fresh tank to 3/4 full and work off that. After filling the tank, bring the hose inside to keep warm. Take it back out when you need more water in the tank.
Hook up the sewer hose, only while dumping.
Open cabinet doors to allow warm air to get to your pipes.
Put a little insulation around the outside shower handle.
Keep the heat turned on.
Bring enough antifreeze to winterize in case of emergency.
44,029 PostsLatest Activity: Feb 18, 2021
