Buzzcut1
Nov 02, 2014Nomad II
hedge wrote:
PS Buzzcut,
do you have dual pane windows? I wasn't planning on building insulating panels for the windows as I have dual pane windows. Of course every bit helps but just not sure if it would be necessary for the hassle.
the foam panels took me all of 30 minutes to cut all of them from one 4x8 sheet of foam. With the exception of the back door they all snap into place with nothing needed to hold them on. I have velco on the back door foam only.
double or single pane it helps. it also eliminates inside condensation on the glass and skylights.
It was 5 degrees in Yosemite last year and we were in t shirts inside with the furnace on its lowest setting and it rarely cycled. I do have r13 fibergass behind every outer compartment door too.
44,056 PostsLatest Activity: May 04, 2014
