Thermoguy
Jul 24, 2022Explorer II
I read that it's not recommended to charge to 100% unless you plan to take a trip. You should only charge to 80% for typical driving to maintain battery longevity. I also read that using supercharges for a tesla can reduce battery life significantly if you use them regularly, occasionally is OK, but not recommended to use them all the time.
I also read that Pilot Gas Stations are adding charging stations to all there locations with the intention that some will be pulling trailers. They will also add for heavy haul trucks. In addition, the state of WA plans to add charging stations to all rest areas.
Right now, the issue is the cart before the horse, not enough charging stations, that is changing quickly.
44,070 PostsLatest Activity: Jul 01, 2022
