RoyB wrote:
For those that do this I am curious how you keep the Truck Camper from being stolen.
Hang a large picture of a lemon on it . :)
To OP : As long as you are able to find mechanical assistance if you should need it in case of a jack or electronic digital failure , its o.k. to off load.
I would test my rig on flat ground to check its balance to be lifted by using 3 jacks. Test it by NOT USING one different jack at a time, see how your LOADED CAMPER is balanced. But you always have to be offloaded on level ground, otherwise you might not be able to lift it using 3 jacks.
Keep it low as suggested and I would keep my awning closed , while unattended. I would use pads under the jack feet to distribute weight and make sure you have good hard solid ground that doesn't puddle in the rain.
If anyone is interested in reading it, I will share my experience. Keep in mind I work my jacks up/down from time to time , clean and wax the tubes , do what the jack mfg.'s suggest to do.
I've had 3 jack failures while loading/unloading, I was NOT able to use the remaining 3 jacks to lift it . ( I guess the balance was not right for whatever reason )
The possibility of road dirt or sand getting into a jack tube or the digital end of electronics being so sensitive to malfunction , I have been advised by dealers and RV mechanics not to unload in remote places.
Two failures at home and one at a dealership. I was lucky to be able to have help to resolve the issues and not in a remote "no cell service place."
#1 , While at an out of state dealership for a repair, I had a motor die while off loading, when the dealer and I tried to hand-crank it, the tube did bind making the crank useless. Dirt and road salt got into the tube I guess. He borrowed a jack off a new camper to unload my camper. If this happened at a CG, I would have to wait at least 24 hrs. for an overnight jack motor delivery.
While at home in my driveway , the motors worked but the tubes froze and when I tried to hand-crank it, the shear pin snapped making the crank useless.
Three dealers suggested not to off load in a remote place w/o help being available. They also suggested not doing it at crowded resort locations where others have reservations to occupy your site the minute you vacate it. This is one of the reasons some CG owners refuse to allow TC's to be off-loaded. I guess it occurs more frequently than people think.
Many years ago one of our remote camper members offered me an emergency fabrication .
Being that I tow a utility trailer behind my camper, if I needed to, I would remove my trailers tongue jack and use heavy duty plumbing straps to attach it to the dead camper jack tube. I would block it with wood blocks and have a temporary jack to use in an emergency. However, for me, I simply leave it on my truck 24/7, but I understand that might not work for some people. For those, make sure you have a back up plan , just in case.
FYI .... It might take two booms to lift a dead camper, this guy lost 2 jacks at the same time:
