Freep
Aug 17, 2020Explorer
Campsite Squatters
Have any of you noticed people leaving their trailers in great campsites on BLM and USFS land during the week and then showing up on the weekends to camp?
Geewizard wrote:jimh425 wrote:
Yeah, we should do everything the way we did 40 years ago, and this issue has little to do with tree huggers. Dumping your germs and food on the ground would be better than nothing, but since we have an alternative, not dumping correctly is just being lazy.
But, if it really isn’t an issue. Feel free to put a sign up in your front yard to encourage people to dump their grey water in your front yard. Report back how that works for you. :D
+2
Yes indeed! Tell us all how that works for you and your neighbors. Step up and show us how it's no problem. Give us all your home address so we can come by and dump our gray water on your lawn.
Just because you can doesn't mean you should. This applies to most everything in life.
https://www.boondockersbible.com/knowledgebase/can-i-dump-my-gray-water-on-the-ground/
(Ignore the "US Forestry Service". It's the U.S. Forest Service. Sloppy writing.....just like dumping gray water on your campsite.)
https://www.gonewiththewynns.com/eliminating-graywater-burning-man
"Why does Gray Water smell so bad? Decomposing food mixed with oils, fecal matter from showering, urine…this all creates disgusting bacteria that is literally alive, hence the awful smells associated with waste water. Sometimes I swear RV Gray Water can smell worse than Black Water!"
https://lnt.org/
Remember Leave No Trace? Used to be common knowledge and a good idea.
