LL8's avatar
LL8
Can’t afford new air bags right now
Moved up to a F350 DRW and need to take a little sag and sway out of the set-up. I can’t afford air bags right now but I do have a set of timbren bump stops left over from my last set-up. The camper is pretty light weight 4200# and only drops the bed about 1 1/2 “ when loaded. Eventually I’ll save up enough for air bags and swapping the factory sway bar for a hellwig but for now I’m thinking:
Upper overload super sway stops ($165) and adding the timbren suspension bump stops.
I had homemade wedges on my bottom overloads with my last set-up but don’t think They would do a whole lot with the DRW.
Are there any other inexpensive adjustments that I may be over looking you would recommend? Thanks
