chevor
Oct 26, 2014Explorer
I like my TST tire monitor system. I can see not only tire psi but temperature while traveling. Tires at 75 psi cold in the morning before moving will be 90 psi and at temps 90 to 110 degrees while traveling. They will vary with deferences depending on outside weather, day and night.
Typically a higher starting cold pressure with cause the tire to vary less while traveling.
44,068 PostsLatest Activity: Jun 17, 2026
