UrbanNomads
May 09, 2016Explorer
A possible solution that I found in the manual is in the sanitizing the water tank section. It states that with the model I have I can pour the sanitizing solution in through the vent hole. So I would assume that I could gravity fill through the vent hole also. It would appear that there is a one way spring tension valve on the main inlet, because it definitely needs pressure to fill the tank. So on that note, can anyone recommend an external pump to use? Again thanks for any help.
44,025 PostsLatest Activity: Feb 26, 2025
