CA_Traveler
May 10, 2016Explorer III
UrbanNomads wrote:Adding a small amount of liquid through the vent should work but not for filling the tank. When you attempt to fill the tank with the vent where does the air go with the vent blocked by water?
A possible solution that I found in the manual is in the sanitizing the water tank section. It states that with the model I have I can pour the sanitizing solution in through the vent hole. So I would assume that I could gravity fill through the vent hole also.
The above suggestion to buy a replacement pump to fill the tank is a good one.
44,025 PostsLatest Activity: Feb 26, 2025
