Second_Chance
Apr 18, 2015Explorer II
I see no need to lube the bearings at 500 miles. However, you do need to lift the wheel and rotate the hub as you pump in new grease. I have a hydraulic floor jack and just lift one wheel at a time (two-axle trailer). If you use improper procedures, you run the risk of damaging the seals on the inside of the spindles and/or getting grease in the brake drums.
44,066 PostsLatest Activity: Jul 25, 2018
