MFL
Apr 19, 2015Nomad II
I agree with others, to raise wheel/turn while pumping slowly.
I would pull the rubber plugs out, just to look at the amount of grease on the outer bearing. If the outer looks good, plenty of grease, the inner bearing likely is greased well too.
It has been my experience, with several new trailers, that very little grease is in the bearings, when shipped.
Very little grease, with bearings not being run often, can cause rust to form. Those rubber plugs pull out easily. I'd just take a look to verify, that they were greased well when you took delivery.
Jerry
Jerry
44,066 PostsLatest Activity: Jul 25, 2018
