Gdetrailer
Oct 30, 2021Explorer III
Most likely a low resolution 480i camera in NTSC Composite video output.
Usable? Perhaps..
Would need a 12V video monitor with Composite NTSC video input and may also need a way to reverse the picture so left is on the left and right is on the right.
Camera also will need 12V to operate plus to power the infrared emitters beside the camera for dark use.
The possibility exists that the missing monitor you do not have may have remotely supplied power via the video cable and if that is so, you have a worthless hard wired camera..
Since I only see one wire going under the tail light, I suspect you have a worthless camera without the matching monitor..
Usable? Perhaps..
