Gdetrailer wrote:
afidel wrote:
I've seen plenty of 2500 diesels with their headlights towards the sky. I'm not sure how much tongue weight those landscaping trailers have but they're the most common offender. Beyond that there vast majority of wdh also offer another significant advantage which is anti-sway and sway is one of those things that by there time it rears its ugly head it's generally too late.
Ah, yes, "antisway" WD, hate to break it to you but if you do not need weight restoration to restore weight back onto the front axles then your WD with antisway will not have enough pressure to be an effective anti sway device..
The two items go together (WD and antisway).
In other words if you do not have enough pressure on the spring bars, you will not have antisway.
Vehicle manufacturers no longer recommend 100% restoration to the front, restoration is what WD is all about..
OP having a 3/4 ton with Diesel engine is starting out several hundred pounds more weight than a gas engine.. The few pounds of weight that might get transferred from the front to rear will be statistically insignificant and the OP will most likely have the spring bars barely tight.. The only issue the OP will have is not overloading the rear axle.
As far as anti sway devices goes, they are a bandaid at best that folks use to cover up too low of tongue weight and/or in sufficient tow vehicle match.
One should never ever depend on an anti sway device to fix problems, one should always ensure they have a good towing match with a trailer of sufficient TW when loaded.. After all, WD hitches and friction anti sway devices can fail, and if they happen to fail when you need it most then you are in a heap of trouble. I am not talking about the bare minimum of 10% TW, but going the extra distance with 15%..
Get it right first, then if it makes you sleep better at night apply some anti sway device.
OP does have plenty of cargo weight (2200 lbs) to cover their trailer without WD even with the revised weight they have given..
There are hundreds of thousands or more contractors towing cargo and flatbed trailers that have never had WD or anti sway devices attached.. Many commercial contractor rigs use pintle hitches (rings) which WD cannot be used with..
Only here on RV forums we have folks believing the WD and anti sway devices must be used across the board on all cases.
Gde, it’s like talking to yourself in a vacuum wrt wdhs on here.
The death grip that people who have no idea how to tow, put on wdhs is nothing short of amazing sometimes….lol.
