carringb
Jan 27, 2014Explorer
Bumpyroad wrote:
are you concerned that the GVWR exceeds the max trailer weight? are you really going to dump 5,000 lbs. of "stuff" into the trailer? this typifies why I think it is silly to base a decision on labeled GVWR unless your actual loaded weight will get up to it.
bumpy
Actual payload of that trailer is only 3,000-3,500 pounds. It can be hard staying under GVWR on tandem-axle toy haulers. Or even triple axles for that matter.
44,056 PostsLatest Activity: May 04, 2014
