420green's avatar
420green
can my chevy express g1500 pull my camper ?
My 2001 chevy express g1500 has a v8 5.8L and can pull up to 6600 lbs according to manual. My camper is a 1998 Forest River Wildwood 24fb and weighs 4500 lbs and a tongue weight of 410. I feel I am pushing it at the tongue weight but feel like a stabilizer bar would help.
See my van specs below please and let me know what you think, thanks.
Gross Vehicle Weight Rating capacity = 7100 lbs
Dead Weight Hitch-max trailer weight : 4000 lbs
dead weight hitch-max tongue: 400 lbs.
wt distribution hitch- max trailer wt. : 4000 lbs.
dead weight hitch- max tongue wt.: 1000 lbs.
gross axle wt rating - front : 3600 lbs.
gross axle wt rating - rear : 3968 lbs.
curb weight-front : 2459 lbs.
curb weight - rear: 2180 lbs.
gross combined weight rating combined : 1200, 1000 lbs.
sae net horse power @ rpm : 255 @ 4600
sae net torque @ rpm: 330 @ 2800
NET TORQUE: 330 @ 2800
Horsepower 255.0 @ 4600
  • Not sure where your getting your numbers from but.....
    GM makes a 5.3L not a 5.8
    Trailer numbers your cited dry or gross weight? I suspect dry, meaning when loaded with stuff it could likely top 5500-6000 pounds
    Then hitch weight will increase to around 700 pounds.
    Do you have that much cargo carrying capacity left in your van once it is loaded with people and stuff? Probably not, but scales is the only way to know for sure.
