Michelle_S
May 03, 2013Explorer III
OK, think you got a number mixed up tho: 16000 is probably the GCWR (max weight of TV and RV combined), because the GVWR on my Diesel Dually is only 13000. So you have a max tow of 10000 but a RV with a gross of 10800 which will put the real world pin weight close to 2000. Remember that Dry weight is usless as many RVs leave the Factory 1000 Lbs or more above that number once options are added. No matter how you look at it, you will be at or over just about every spec of your TV. Me, I wouldn't do it. Only you can make the final decision.
44,027 PostsLatest Activity: Mar 05, 2025
