hmknightnc
May 03, 2013Explorer
You asked this question a couple days ago about basically the same spec FW with the same truck. The answer is still yes it will do fine. You can load the FW all the way to it's 10,800 limit with no issues wieght wise on that combination. No need to limit water on board or anything else if you stay within the 10,800 of the trailer.
The gasser 3.73 will fine also but need to run a higher rpm pulling steep hills and heavy headwinds
44,027 PostsLatest Activity: Mar 05, 2025
