zackyboy3rs
May 05, 2013Explorer
LarryJM wrote:zackyboy3rs wrote:hmknightnc wrote:
You asked this question a couple days ago about basically the same spec FW with the same truck. The answer is still yes it will do fine. You can load the FW all the way to it's 10,800 limit with no issues wieght wise on that combination. No need to limit water on board or anything else if you stay within the 10,800 of the trailer.
The gasser 3.73 will fine also but need to run a higher rpm pulling steep hills and heavy headwinds
I also asked this in the 5th wheel forum and all i got was that i should not do it &
That i was over weight. I guess i just wanted a second opinion. Thanks
Hmmm you asked the same question in a forum where those answering are 5er owner's with tons of experience and didn't get the answer you seem to want so now you are asking the same question in a forum not specifically applicable to your trailer hoping for WHAT:h ... a different answer ... some from people maybe only towing a pop up:S
IMO this is the wrong forum to get a good "second opinion" as you imply you are looking for ... I would replace that "second opinion" with maybe "rationalization".
Sometimes the logic of folks make we wonder:h
Larry
Yes, on a different FW. Thanks for your smart remarks. I guess you had nothing to provide.
44,027 PostsLatest Activity: Mar 05, 2025
