- wickedstang03ExplorerAny know why I cant view photos I tried to change my preferencees but when I go to that page it says the page you are trying to reach has had an unexpected error
- myredracerExplorer II"B" shows no fuse(s) associated with it and is for the incoming positive #8 conductors from the battery and converter. The battery connection at "B" would be connected to a mini circuit breaker in the A-frame near the battery. "A" shows all the fuses for the load circuits but the factory was lazy in not labeling them.
To label the DC fuse circuits, you'll need to systematically turn fuses on and off and see what fuse controls what load(s).
You have a Magnetek 80D which would look similar to this with "B" being at the top of the photo:
The panel would be wired like this:
- kearlmsExplorerI usually leave all my 120's on with the exception of the water heater. This way I dont flip the switch and accidentally turn on the water heater element and blow it if there is no water. The gas and 12v control board work fine with this breaker off.
- I cannot see all the fuses holders. Some have a buss B for unfiltered power.
You could be correct as I also cannot see complete power connections. - OzlanderExplorerSome of you guys are all wet. There is no Buss A and Buss B.
It says right on the placard that all fuses 1-11 are on Lug A and Lug B is for the battery lead. - wickedstang03Explorerthat all sounds like Chinese to me lol I think I remember the guy who I bought it from say he dry camped with the furnace working for almost a week befor he needed charging
- That is true prichardson, however the label on the unit says they are not.
I would say is should be A could be filtered and B is not. - prichardsonExplorerMy bet is that Buss A and B are common to each other and are used to make the + connection between the converter the battery and the fuse panel. This could be confirmed with an ohm meter.
- Bird_FreakExplorer II
wickedstang03 wrote:
See if it runs without shore power. If it works your good to go.
How would I know if the furnace was put on buss A - You need to locate the wire that goes to the furnace. Might be the same color in panel and furnace.
Then look where it is attached on DC buss work.
If not the same color or you can't find it, Use a test light to verify whether there is power at the furnace. If power is present, go to DC panel and start removing fuses until power at the furnace goes away. then mark it.
