What is this metal inverted triangle under the trailer.? Can it be removed or cut away? It keeps on hitting the driveway when i back up on my driveway. Can I remove it ?
If it is what it looks like it is. That is what it is supposed to do. It is designed to protect the back of the TT, and the sewer pipes by letting you know you are getting ready to drag. Some are actually strong enough to lift the TT as they drag. You can take them off. But then you may at some point lose your sewer connections, or holding tanks.
