What is this metal inverted triangle under the trailer.? Can it be removed or cut away? It keeps on hitting the driveway when i back up on my driveway. Can I remove it ?
It's called a "skid bar". It's purpose IS to drag the ground and keep the back of the camper from dragging the ground. As stated above, you CAN cut it off, but ... as stated above ... you run the risk of dragging something else on the ground causing more damage ... like your bumper or stabilizer jacks.
