What is this metal inverted triangle under the trailer.? Can it be removed or cut away? It keeps on hitting the driveway when i back up on my driveway. Can I remove it ?
It is like a bumper - protects the trailer chassis from damage when on uneven ground. You could replace it with a heavy duty wheel (caster) which will serve the same function.
