thehippie
Mar 05, 2015Explorer
Can this be removed?
What is this metal inverted triangle under the trailer.? Can it be removed or cut away? It keeps on hitting the driveway when i back up on my driveway. Can I remove it ?
schlep1967 wrote:thehippie wrote:DutchmenSport wrote:This looks nice. Where can I get it?
This is a good solution. It works and helps the dragging from tearing up your own driveway:
Those braces are there to stop you from doing damage. Not for continued dragging of the trailer. The problem with the wheels is it encourages you to continue moving. If you lift your trailer off the axles by one corner of your frame you will most likely do damage by twisting the frame.
