ktmrfs
Jun 28, 2022Explorer III
as mentioned as long as the puncture is within the repairable area and within the repairable dimensions for size it should be able to be repaired. Now the only approved repair method from almost or all tire mfg is a combo plug/patch. Usually done with a mushroom shaped patch. the patch is pulled through from the inside to keep water etc. out of the cord and the patch on the inside provides the patch.
requires dismounting the tire from the rim.
I have had one ST tire repaired this way by discount tire for a nail in the tread area. No issues
X2 on discount tires.
