RCMAN46
Jun 29, 2022Explorer
JRscooby wrote:B-n-B wrote:RCMAN46 wrote:
Was that on the back tire of the trailer? I picked up a 3/8 bolt once had it repaired from the inside with no problems. Interesting it was the rear tire on the trailer that got the bolt.
Yep rear tire on passenger side.
I would bet most road hazard flats on TV/TT or 5th wheel units are rear passenger of trailer. Every time hit, but not picked up by a tire the crown of road will likely push it to right. Most of them just work over to shoulder, never damage a tire. Right side trailer tires are most likely to run on the shoulder. Plus, the tires on trailer tandem are running close together. In the lane or not, most time tire hits bolt or nail, it stands up. All other positions, it will fall back down. But when front trailer stands it up, it don't have much time to fall before the rear hits.
I agree with your analysis. Mine was on passenger side. My 5th wheel tires track wider than the TV so the TV may push the bolt closer to the shoulder where the trailer tires do as you described.
