JRscooby
Jun 30, 2022Explorer II
dedmiston wrote:Grit dog wrote:
@bucky, how many plugged tires you had self destruct in a short time, or ever?
Put me down for a "zero", boss. My plugs have all held.
I have had several I suspect, and at least 3 I am sure of. Costly enough that I told all my drivers if I saw a plug kit in their truck, they where fired on the spot.
Last 1 was rated at 11,800 lbs at 130 lbs pressure. End of 3rd day, found nail hole center of tread. Told driver to call tire shop, if could not be patched safely for steer, replace it. Driver decided to plug. But what could not be seen from outside was the steel caused the nail to go in at angle. He worked to get the plug to straight in. The plug sealed the tread real good. Next morning that tire had a bulge half the size of my head. Broke it down, on the inside the plug missed the hole by half inch. If we had put a load on the truck that night the truck would of been tore all to swell.
Other times blowout I suspect caused by slow leak in a day's run.
