wanderingaimles
Jan 20, 2020Explorer
With a family of 5 plus a large dog, your issue is likely to be cargo capacity more so than tow cap.
There should be a door column sticker listing your cargo cap, add up weights of family and in vehicle cargo. Add 100 lbs for a weight dist hitch and then see how much room you have left. That's what you have available for tongue weight.
Tongue weight should be about 12% to 15% of your total trailer weight, so as an example if you had 800 lbs available for tongue weight, your trailer loaded for travel should weigh no more than 6000 lbs which would require between 720 and 900 lbs of tongue weight.
Hope this helps.
Hope this helps.
