- AvaExplorerI saw a set of rear lights with the magnetic bottom and wiring to front like any other trailer 4 wire plug very cheap at outdoor market in Yuma last year. I was going to buy them even though I didn't need them cause they were only a few dollars. They are available anywhere.
- ughExplorerWould it be cheaper and far more reliable to hard wire it for lights? Its really easy to do.
- The_TexanExplorerBeen using ours for 3 years now and the comment about loading batteries every day is pure BS. A set of batteries will last 3-6 months of regular towing. If you left the taillights on 24/7 and used the brake light every 2 minutes then you "might" have to replace every few days, but some folks have never used them, so have no idea how they work. I bought the ones recommended on the 411 towing forum when I did the research. Pricy ? not really, when you figure the cost of a custom wired system with diodes and such. The newer ones today are even better and I would go to the 411 forum or another tow truck forum and do the research.
The reason I went with wireless was that the GM dealer knew we towed our trucks and flat told me, that the electrical/electronics warranty would be void if there was any intrusion into the factory wiring harness other than a plug & play system. To me, $175± was cheap piece of mind to keep my warranty intact. - mkirschNomad II
Just Cruzzin wrote:
Kind of like 6 of one, half dozen of the other.
That's a rousing vote of confidence in a product, when you consider the source.
I only start worrying about the quality of the product when the negative feedback approaches 90%. - spoon059Explorer III would suggest you find a tow truck forum and inquire there. They have high quality wireless marker and brake lights in that industry. I'm sure you would pay good money for them, and I'm sure the battery life isn't good enough to last all day without recharging though.
- WyoTravelerExplorerInteresting. Didn't know they made them. Ones I checked them out seems like batteries are pricey. Load them up with $15 worth of batteries every day you're on the road. Batteries are good for 24 hours. That could add up fast. Why not just get your toad wired? They make a wiring harness for some toads that make it easy to wire. If not just hire it done. Couple of months on the wireless system buying batteries would more than pay for having your toad wired.
44,056 PostsLatest Activity: Jan 12, 2020
