JBarca
Dec 07, 2013Nomad II
Wes Tausend wrote:
Snip....
This turned out to be a likely key to the leak. I noticed that sighting down the rain gutter reveals that very moderate jack pressure immediately "swoops" the shallow rain gutter (actually the whole camper roof).
snip...
Anyway, when the slide is in, and the jacks are barely down, rain then gathers towards the center of the roof, spills over the side, overpowers the useless token rain gutter, and runs directly across the joint and seal that is supposed to seal the slide roof when closed (if that makes sense). I'm not sure how the rain is ultimately getting in, but there is plenty of it available in the directed white-water stream, that is inadvertently created.
Now this poses an interesting situation. I will bet that all travel trailers suffer from the slight swoop or sag when the jacks prop up the ends of the frames.
Wes,
Do you have a picture of how your slide system is built? If you have fiberglass walls, I have seen some made where the slide flange has a seal bulb that presses to the side wall of the camper. If the wall has enough bow in it, the slide may not seal and water running down from the roof "might" enter.
Mine is made different. 1st I have aluminum sides. 2nd my slide has a trailer frame aluminum flange that rests inward of the camper. Then in that trailer framework, the actual slide flange seals however the entire slide flange is in-board of the camper side. There is also a 2nd semi useless gutter above the slide, the one above the slide which I added gutter extensions to. This setup helps from water flowing down the wall or blowing down the wall of the camper under tow to helps deflect off water before it ever reaches the seal. See here
How is yours made?
44,066 PostsLatest Activity: Mar 14, 2015
