Camp__Forrest__'s avatar
Aug 19, 2014
Can't find fresh water drain on 2000 AF1150
Update 10/2/14 - I found it! Check the last post for details.
OK, I give up. I have looked around, under, and into every nook and cranny on this thing and can't find the fresh water tank drain. I've found the grey, black, and low-point drains, but I can't seem to find this one.
I'm sure someone here has one and can tell me where it is.
  • CFC, in looking for the valve, did you find the discharge tube on the underneath side of the camper? Look for the discharge tube and then within a couple feet of that in the nearest compartment. wnjj, on my EC it is on the floor of the waste valve compartment, tucked back close to the main door.
  • RICKIM's avatar
    RICKIM
    Explorer III
    I don't know if they relocated it from 2000 to 2008, but mine is on the floor in the dump valves compartment.
    Hope this helps, good luck.
    Rick
  • wnjj's avatar
    wnjj
    Explorer II
    Is there one? On my EC, I don't know if there is. I just run the pump with the low point drains open.
