zcookiemonstar
May 22, 2018Explorer
jaycocreek wrote:
I am not sure it is a typo as here is another one listed in the specs as only 2460 pounds for payload or Dave Smith motors has issues.(laughing)
2012 Ram 3500 Laramie Longhorn Mega Cab DWR Short BoxSpecs and Dimensions
Compression ratio:17.20 to 1
Engine horsepower:350hp @ 3,000RPM
Front headroom:1,041mm (41.0")
Rear legroom:1,151mm (45.3")
Exterior height:1,989mm (78.3")
Front legroom:1,041mm (41.0")
Interior maximum cargo volume:2,044 L (72 cu.ft.)
Exterior length:6,309mm (248.4")
Engine torque:800 lb.-ft. @ 1,500RPM
Front hiproom:1,605mm (63.2")
Payload:1,116kg (2,460lbs)
Passenger volume:4,055L (143.2 cu.ft.)
Turning radius:7.1m (23.4')
Front shoulder room:1,676mm (66.0")
Wheelbase:4,077mm (160.5")
Towing capacity:5,806kg (12,800lbs)
Engine bore x stroke:107.0mm x 124.0mm (4.21" x 4.88")
We all know that a modern Dodge dually can carry more than 2460 pounds.
I have noticed a lot of Dodge trucks listed this way. What the dealer is doing is showing the rating for a SRW instead of a DRW. I have even seen on the original window sticker the rating for a SRW but then in a different area it shows the higher rating for the DRW.
